ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: dupont#24 on November 19, 2009, 07:22:06 PM
Title: Hood clearace
Post by: dupont#24 on November 19, 2009, 07:22:06 PM
I just put 89 geo motor in my 87 sammy and I have major hood clearance problem with that bigger horn on the 89 injector.I don't think just cutting out the x brace under the hood is going to do it.I really don't want a body lift but it is looking like I have no choice .It looks like it will take at lest a 2 inch what do you guys do about this problem . will a 1 inch body work
Title: Re: Hood clearace
Post by: mrfuelish on November 19, 2009, 10:49:07 PM
man I would cut the motor mounts and lower the engine before the body lift, you can even cut the frame mounts off and lower them and weld them back on and then lower the trans mount to match.
Post by: Bobzooki on November 20, 2009, 07:13:20 AM
Hood Scoop?
Post by: Cuthulu on November 20, 2009, 09:16:21 AM
One advatage to this is that if you did a suspension lift it would take off some extra tension in the CV joints.
Post by: Rhinoman on November 20, 2009, 11:08:17 AM
I would go for the hood scoop. If you don't have a suspension lift then lowering the motor may give you clearance problems with the oil pan. Lifting the body will make it less stable and its only too low in one small area.
Post by: dupont#24 on November 20, 2009, 03:47:19 PM
where do yall get this hood scoops any pics I have plenty of lift 3inch rear spings on front and yj on rear.and still like 2inces shooting hood
Post by: ebewley on November 20, 2009, 03:48:28 PM
Here's one from our Gallery section..
(http://www.zukiworld.com/forum/gallery/0/22_23_01_09_6_48_26.jpg)
Post by: dupont#24 on November 20, 2009, 03:52:28 PM
will this fit a sammy
