ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: Minmatar on November 24, 2009, 10:50:13 am
Title: T-Case Crossmember
Post by: Minmatar on November 24, 2009, 10:50:13 am
So i have a 1993 4 door Suzuki.
I bought a 1994 4d cross member thinking it would be the same........wrong. The 93 had this open C frame design and thick medal compared to the 94's thin flat 3/16" bubble stamped cross member. Anyone know if it will still measure up?
Title: Re: T-Case Crossmember
Post by: wildgoody on November 29, 2009, 10:52:04 am
Should fit, the frame and transfer/tranny assembly didn't change any,
are you sure it's not a part from a Sport instead? those could be different
Post by: ncspack7civic on November 29, 2009, 12:36:34 pm
Yea i just had to swap my transfer case crossmember since it was bent real bad. I had the same concern since i had the stamped C shape and the one that was sent to me was the flat bubble one. They swap with no problems. I think im going to like the bubble crossmember it seems to hug the underside alittle bit tighter. I kept getting the stamped C crossmember hung up on thing and thats what did it in.
Post by: Skyhiranger on December 01, 2009, 02:11:04 pm
All 4wd crossmembers are interchangable....both 2 and 4 door, from 89 to at least 98.
Well, except for probably the 96-98 sidekick sports.....I think the frames are wider, so therefore they won't interchange, obviously.
