ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: chevycotton77 on November 28, 2009, 01:26:14 AM
wich should you put on first? the body lift or suspension? or does it really matter..
It doesn't matter, personally i would go for a different body lift I wasn't impressed by the Calmini kit, the metal work isn't even painted or plated. The suspension kit is good though.
I would put the body lift on first, depending on how you are lifting the body off the frame, if you are using a hydraulic jack to do it the lower the frame is to the ground the less you have to raise the jack.
I just did a 2" body lift with a 2 ton floor jack and needed 2 pieces of 4x4 and a 2x4 stacked to get enough lift and almost used the full lift of the jack
OK i would do the body lift first,i just did mine this summer and the body is allot E-ZER than the sups lift make sure you put alto of WD-40 on everything nuts|removethispart|@bolts start with the front first and have a helping hand around just make sure you keep everything loose until you are done with the front end because its a pain to install just follow the directions and good luck doing it in 8 hours like they said,if everything is rusty good luck . i got a 4 door 1994 sidekick with a calmini 6in combo 31in bf Mk2 tires 90000 Ramsey winch and Suki tuff front and rear bumper's
I'd like one of those 90,000 lb winches! where did you get it ;)
