ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: keith on December 10, 2009, 10:50:37 AM
Title: Locked hubs and gas mileage
Post by: keith on December 10, 2009, 10:50:37 AM
Have you noticed any difference is gas mileage when driving with the hubs locked?  In the winter I usually keep them locked all the time.  My last tank with them locked was exactly the same as the 2 tanks before that weren't locked.  A bigger issue on gas mileage has been the colder weather.
Title: Re: Locked hubs and gas mileage
Post by: karl214 on December 10, 2009, 01:23:51 PM
Yup, Mine goes down in the winter .. Locked them in last week... Going to be a long winter...LOL..
Post by: jschaft on December 10, 2009, 02:30:06 PM
I just replaced my old hubs, and I had to run with the old ones locked for a while.  I was averaging 21-22 mpg with them locked.  I do notice a difference since I replaced them,and not driving with them locked, but only 1 or 2 mpgs.
Post by: Bobzooki on December 11, 2009, 09:29:50 AM
Post by: cwymer on December 11, 2009, 09:49:51 AM
when its that cold outside the computer tells the injector to stay open longer, and squirt more fuel,  hence the mileage drop.  thats how a lot of those cheap performance chips work.  they trick your comp. into thinking its -30 outside and in turn it dumps more fuel.  more fuel=more power
Post by: Bobzooki on December 11, 2009, 09:55:49 AM
Nice try, but not true.  When the ice is off the roads, it's still the same temperature, and my mileage comes right back up to 25, as soon as I unlock the hubs.  We get a lot of bad road conditions for a day or two (usually), then the roads are cleared off - even though the temps stay in the same range.  I only lock in the hubs when it's really necessary (usually not more than 15 or 20 days through the whole winter season), and the hubs are just like a "lower MPG" switch.
Post by: cwymer on December 11, 2009, 10:56:09 AM
its more draw on the engine.  nwhen yoou lock the hubs  the engine has to turn 4 wheels instead of just 2.
Post by: Bobzooki on December 11, 2009, 11:42:06 AM
Absolutely - even if you're not in 4WD, when the hubs are locked you're turning the front axles, the front diff, and the front drive-shaft (what the English call the prop shaft for some reason).
