ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: Tazweld on December 19, 2009, 08:29:19 PM
The short side axle keeps popping out if the dif housing,
Does any one know why or what has to be done to correct this issue,
I installed a Calamini 3" lift, on the orginal install the axle stayed in place
The clip on the end of the shaft is what holds these in place, if it's
broken (gone) or just collapsed, it won't hold, on the flip side, if it's
too tight the axle is a #%$^#& to get out, I sheared one of those
little buggers in half removing an axle from a GV front end, beat the
crap out of the axle too, good thing I was making a flange side to
run the same half for both sides
