ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: juggster on July 25, 2004, 03:29:50 AM
hey guys, i want to make some spring spacers for my sidekick, i plan on making them between 1.5"-2"thick, that way i can remain with my standard shocks since i don't go off roadin. What i would like to know is the dimensions i need to cut for it, so the outer diameter, and the inner one, plus also what material woukld be good to use, thanks
Every one I know that did it used the bearing plate as a template (That's the thing the strut mounts to on top.)
thanks for the help, but i am currently using my zuki, so i can't remove my shocks and use that as a template, is it possible for some one to get the outta diameter and the inner diameter for me PLEEEEAAASSSE?
Also would nylon be a good material to make it outta of?
use aluminum... and i dont know the dimensions just yet, but i'm working on building some now. a buddy of mine is roughing out something in his mahine shop, and after we get it fine-tuned, i'll let yall know how to make them.... you cant just find this info out there, its some big secret!
goldfinger did you realize this is a 5 yr old post.......YOur diggin deep........ :laugh:
Well, at least he did a search eh?? ::) I'm thinkin orig poster prolly been there done that long ago by now... but hey goldfinger, post them specs... or just contact jeff1997 & buy a set of his, I hear they're both good & reasonably priced... (free plug jeff... even though I don't have your spacers, sry ^^)
Well, for future searchers, spacer dimensions are 4"OD and 2.5"ID(with a 1/4" on one side)
