ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: JDMCRX on July 26, 2004, 02:34:15 AM
I want some rims found some they are 15x7 and the offset 0 i want them to be wider and stick out the fenders a bit will these stick out?
Wasn't it established that offset is how far the wheel mounting space was from the center of the wheel? If the wheel has 0 offset, and it is 7" wide, then the backspacing is 3.5". Stock backspacing is 4", and a stock wheel is only 5.5" wide. So, if my calculations are correct, your new wheels will stick out 2.5" further than the stock wheels plus however much farther the tires stick out.
OK guys figured it out here are the spec on the wheel.
15X7 5-5.5 0 4"back space
(http://www.uniquewheel.com/images/products/297.jpg)
so stock is like 4 1/4" this one is 4" but has a 7" surface and stock is 5.5 so this rim is 1.5 wider and so forth.
Cause on my stock rims when i go offroading the tire hits the frame a bit so i guess with this the tire will be 1/4" out more and 1.5 wider :-[
Its weird tho if the rim is 7" wide and its a 0 offset would the backspacing not be 3.5"??? I dunno
Ok guys found some rims 15x7 with a 3.75" back spacing and there white ill just spray them black
so i guess they will be out .5" more and 1.5" wider.
