ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: jamrensuk1 on December 29, 2009, 09:15:37 AM
Title: Rear wheel studs
Post by: jamrensuk1 on December 29, 2009, 09:15:37 AM
Anyone know where to find rear wheel studs for an 87 samauri in the phoenix az area.
Title: Re: Rear wheel studs
Post by: Drone637 on December 29, 2009, 11:12:06 AM
Check with your local Suzuki dealer.  They can usually order the parts in without issues.  You might also check with your local tire dealership as they need to order replacement studs all the time.  Napa or Autozone should even be able to pick up a set for you.
You can use studs off of a Geo Tracker/Suzuki Sidekick as well.  The front studs are a touch longer then the rear but can also be used without issue.
Post by: 8yota9 on January 08, 2010, 10:16:50 AM
i got my studs at nappa for my 87. dose eneybody know if there are eney beat in type studs i can use for the front of my 87 sammy? the little groves the hold the stud in on the knuckle ar beat up and rounded out. they do not secure the stud . eney ideas?i tried toyota studs but they are to fat.
Post by: Skyhiranger on January 08, 2010, 11:29:10 AM
The later samurais use the splined type studs.
Post by: zukimoo on January 10, 2010, 12:19:30 PM
you can always put two little tack welds to hold them in place.
Post by: john1974 on January 10, 2010, 09:36:34 PM
Alot of local stores carry them in stock, or as above post mentioned can order them.
