ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Zukill on January 20, 2010, 01:32:41 PM
Title: Charcoal Canister.
Post by: Zukill on January 20, 2010, 01:32:41 PM
Hello!
I am new, but i was hoping to get my samurai officially running before introducing myself...
My charcoal canister is leaking from the bottom... the port coming off the bottom has no hose to it and it wont idle because if it.
Is it supposed to be plugged? or where does it go? does someone have a picture for reference?
THANK YOU!
much appreciated if you can help.
Title: Re: Charcoal Canister.
Post by: Zukill on January 20, 2010, 02:43:54 PM
it acts as if it is starved and fuel is really pouring out of it...
Post by: yzf438 on January 20, 2010, 05:39:02 PM
get rid of it and all the smog crap u can.  mine runs good with out it.(makes a good tire chuck)
Post by: wildgoody on January 20, 2010, 05:52:53 PM
Sounds like something is hooked up wrong, the canister is supposed
to filter out gas vapors from the tank, check your vacuum hose routing
and follow the line from the tank, should be a small one, smaller than
the fuel line to the pump.
Post by: Zukill on January 20, 2010, 06:11:51 PM
thanks, ill check it out tomorrow, its too dark right now.
i remember there being 3 lines from the tank going to the top of the canister, they all looked correctly placed (side wise they wouldnt fit otherwise)
Post by: wildgoody on January 21, 2010, 02:05:28 PM
Is this a TBI Injected Sammi or a Carb?
3 lines would be supply, return and vapor
Post by: Zukill on January 21, 2010, 10:23:47 PM
its carbed, '86
Post by: Zukill on January 22, 2010, 10:29:34 AM
can anyone else help? im not sure that its  the problem now, i disconnected the charcoal canister and it STILL won't start.... it jjust cranks and sputters but doesnt idle for more than a second or two....
please..
Post by: Zukill on January 26, 2010, 12:19:06 PM
wouldn't let me reply, but i fixed it!
thank you wild, it was stuck, i tapped the top of the input fitting alittle with a screwdriver handle and it slipped unstuck, and stopped flooding.
ill post pics soon!
thanks again!
all i have now is a pic next to a friend's '95 wrangler
