ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: San Diego Sam on February 02, 2010, 09:07:02 PM
Title: opinion on best rock sliders, please...
Post by: San Diego Sam on February 02, 2010, 09:07:02 PM
Hi -
New to the world of Samurai -  fun stuff!.  Just picked a a really clean '87 with a lot of goodies, but no sliders.  I have looked at Calmini, Petroworks, and shrockworks.
Petroworks - doesn't run the full length.
Calmini - looks clean, but how strong?
Shrockworks - beefy, but 66lbs.
Opinions, please.  Thanks!
Title: Re: opinion on best rock sliders, please...
Post by: ack on February 03, 2010, 03:22:07 AM
ZOR RockBiters
Like Shrockworks
direct or via lowrangeoffroad.com
Post by: Drone637 on February 03, 2010, 01:46:37 PM
I just bolted some angle iron on the side.  Works great for me.  :D
(http://lh3.ggpht.com/_86HP5-adsWc/SlLSY-NZH8I/AAAAAAAAEOk/8kwa_YhKf1M/s512/SSPX0112.jpg)
Post by: San Diego Sam on February 04, 2010, 09:28:32 PM
angle iron would definitely be the cheap/easy way.  have you put any weight on your sliders? Just wondering if a slider really needs to be braced to the frame?
Post by: Drone637 on February 05, 2010, 05:39:55 PM
Oh yea, I've dropped it on all sorts of stuff.  Never even budged.  For proof check out the video:
http://www.youtube.com/Drone637#p/a/u/0/SaVr8eofYrU (http://www.youtube.com/Drone637#p/a/u/0/SaVr8eofYrU)
I have 4 holes drilled through the body with some 3/16th on the back side to make sure that I have plenty of strength on the mounts to keep the bolts from pulling through the body.  The front two go into the cab, the back two go just underneath it.  There is room for a 5th bolt if you want to put it on there but I haven't found it necessary.
This does not allow for the use of an added bar to help keep the vehicle off of trees and the like, and I wouldn't recommend welding a bar onto this sort of configuration due to the extra leverage on the body.  If you want the bar I would still use the angle but come off of your frame as well.
Post by: shakydoug on February 05, 2010, 06:04:25 PM
I'd say the the angle iron works?
MYTHBUSTERS
Post by: San Diego Sam on February 05, 2010, 06:17:16 PM
Based on that video - I'd say so!  Got sucked into the Calmini formed rock sliders - they say not to worry about durability.  Probably should have gone with the angle iron.  Anyone using the Calmini formed sliders?  They are the ones that have the triangle bend.
Post by: Dazookster on February 06, 2010, 09:15:28 AM
anther for just angle iron mine is held on by 6 self tappers hasn't budged at all either hit some rock pretty hard too.
Post by: Bigzook on February 06, 2010, 01:28:26 PM
I have the Calmini sliders and like them a lot. I have had zero problems banging them on rocks from underneath. The only thing I would watch for is a hard hit from the side. I have a slight bend right in front of the rear tire from a very hard slam against a tree. If I did not have the slider on then my tub would be severely caved in there.
Post by: ecoast on February 06, 2010, 01:35:01 PM
1/8 or 3/16" on the angle?
Post by: San Diego Sam on February 06, 2010, 07:49:24 PM
Calmini says 3/16.
Post by: dupont#24 on February 06, 2010, 08:17:57 PM
Shrockworks
Post by: San Diego Sam on February 06, 2010, 08:20:23 PM
Nice rig.
