ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: penguin on February 15, 2010, 07:36:40 AM
Title: installing header on 96 x90
Post by: penguin on February 15, 2010, 07:36:40 AM
just got a header (used) calmini for my 96 x90  and was wondering what to do with the sensors at the cat. i would like to eliminate the cat,do you put the sensors in the replacement pipe or do away with them altogether. if you do away with them will you have to remap the fi.
Title: Re: installing header on 96 x90
Post by: ToyYoda on February 15, 2010, 08:33:52 AM
Why are you planning to remove the cat.? Too much exh. flow is not always in your best interest. Then there's the O2 problem. What are you trying to do ? Lastly your post might get a better response under the Performance/Mod. form.
Post by: penguin on February 15, 2010, 10:02:25 AM
good point on the move to performance forum..   looking for more performance.
Post by: wildgoody on February 15, 2010, 07:14:03 PM
If you have 2 sensors at the cat, one before and one after, the after tells
the computer that the cat is bad, and will set off the check engine light.
