ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: Rhinoman on February 24, 2010, 12:18:12 pm
Does anyone have any information on what one of these does? I have one on the bench that I'm playing with, I have pulled the code from the software and I'm tracing out the circuitry. I have a wiring diagram which shows me which pin is which but I could do with some more info from someone with an FSM or who has knowledge of the 4 speed. Here in the UK we see more UFOs than we do auto transmissions.
I have a pin marked 'Light' which goes to the exterior lights system combination switch - Why???
Theres also a connection to the brake light switch - Why???
There is a lamp marked P/N but only the N switch appears to be wired to the TCM, does the lamp do anything in park???
All info gratefully received, details are being published here:
http://www.rhinopower.org/ECUs/TCM_57B40/TCM_57B40.html (http://www.rhinopower.org/ECUs/TCM_57B40/TCM_57B40.html)
I have a 95 FSM for my 95 Tracker, but it's a 3 speed auto. I've read through it for other jobs many times and never came across any info on the 4 speed auto. That must be for a 4 door? I'll check again later today and see what I can find for you.
I think its for a 95, this TCM came my way cheaply because the guy that had it didn't know what it was for. I know that there were a couple of people who were interested in fitting a 4-sp into an early model so I thought I'd have a look inside it. Suzukiinfo.com is down at the moment, I'll keep looking and see if I can find any other info.
James
Look here. http://www.acksfaq.com/trackerfsm.htm (http://www.acksfaq.com/trackerfsm.htm)
Look here. [url]http://www.acksfaq.com/trackerfsm.htm[/url] ([url]http://www.acksfaq.com/trackerfsm.htm[/url])
I couldn't find the correct info there. I have found the wiring and some diagnostics info at this site:
http://www.suzuki4x4.net/manual/ (http://www.suzuki4x4.net/manual/)
I just need to work through it and see if it answers all my questions.
Well try this one then. http://www.acksfaq.com/96-FSM-v1-7A-pdf.htm (http://www.acksfaq.com/96-FSM-v1-7A-pdf.htm)
Well try this one then. [url]http://www.acksfaq.com/96-FSM-v1-7A-pdf.htm[/url] ([url]http://www.acksfaq.com/96-FSM-v1-7A-pdf.htm[/url])
Does that link work for you? all I get is a red x. I'll try it again when I get home.
Works for me.
I managed to download the file at home, there is a bit of info in there that should help, thanks. I still don't know why it wants to know that the headlights are on ???
That is an odd one.
I've finished tracing through the circuitry now so I can associate processor pins with functions. I'll feed that into the disassembly of the code and see if any of it makes sense.
