ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: us74k5 on February 28, 2010, 11:04:56 am
Just replaced the 1.3 in my 86 sami. Now the engine starts up just fine, then just proceeds to idle all the way to 4-5k. Twice it has started and idled just fine for a minute or so, then it just races away. Any help would be much appreciated, thanks.
this sounds like a major vacuum leak issue to me, I'd look into all the vacuum hoses, make sure they're tight/solid and not leaking. also make sure your carb isnt loose on the manifold.
Carb is solid, cannot find a vacuum leak anywhere... I have no idea what else to look at.
Anyone have any ideas? I have gone over the engine several times, no luck. Cant seem to figure this one out.
spray carb cleaner around the outside and listen for changing
RPM, also check the brake booster line, however a carb engine
should run bad and stall with a major vacuum leak like that, where
a FI engine will rev due to extra air.
Also check the fast idle cam and choke to make sure they are
turning off when the engine warms up
