ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: muddog199 on March 03, 2010, 07:26:23 pm
ive put it on the battery charger and checked the connections. the starter just won't engage. any ideas?
faulty starter relay most likely, I think I've read its a common issue. lowrangeoffroad.com sells a relay kit to fix it. if you can, get a 2nd person and see if you're getting voltage to your starter when you turn the key.
What Bobthebiker said. A quick test is to jump 12v straight to the starter solenoid and see if it starts. Make sure the rig is in neutral first!
thanks but i just tried and that didn't work. I'm taking the starter out and ima go take it to advanced for them to check it
yep, definitely have them check it then. I'll locate the relay kit if you want to replace that as well. I spend like 90% of my day online right now, so its pretty easy.
yea the starter is bad, so ima try and find one on ebay. but someone said u can have them rebuilt? is this true?
Most towns have a shop that rebuilds starters and alternators. When I lived in Chico Calif, I knew of 3 within a few miles of each other. Its so much cheaper to have it rebuilt than buy a rebuilt. I actually had one rebuilt in my Corvette and it cost me $30 when it was over $200 for one at the auto supply..
yea they hav a new one at advanced for $93 but ima check the local rebuild shop tommorow, i already found the #, thnx for all your help. i just got my samurai about a month ago. my friend got one about a yr ago and ive been in love ever since, ive been savin 4 about 6-8 months. its kkinda hard wen im still in highschool
