ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: raysidekick on March 04, 2010, 05:20:42 pm
Title: 3 speed automatic wont shift when cold
Post by: raysidekick on March 04, 2010, 05:20:42 pm
I have a 89 sidekick 3 speed auto 4wd. It ont shift when its cold can anyone help me wiht this? Also I was wondering if I can put another transmission for a tracker like a 90 without changing the ecm? I have no idea on this since I just purchased. Thanks in advance Ray
Title: Re: 3 speed automatic wont shift when cold
Post by: wildgoody on March 04, 2010, 05:58:20 pm
That's a valve body issue, just a good cleaning and you should be good to go.
Often newly changed trans fluid in a neglected transmission will cause this
kind of problem, that's the action of the high detergent in the new fluid
cutting loose all the old gunk from inside.
You might get away with a fluid change, but you got to drop the
pan and as long as you are there, check/change the filter and then you
might as well clean the valve body, there should be plenty of documentation
online for the 3 speed as it's a GM TH180 tranny. If you aren't comfortable
doing the cleaning get a friend who is, they aren't really that bad tho, just watch
where all the little parts go, write it down, keep track of the check balls and
above all else, have fun !!
Post by: raysidekick on March 04, 2010, 06:09:54 pm
 I will do this tomorrow and let you know if it is a sucess. Thanks again Ray
