ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Rubberducky on March 21, 2010, 08:49:34 AM
I need a hardtop for my 1990 Suzuki sidekick. Will the Sunrunners and Geo Trackers fit mine?
Thanks..
Yes it will, except possibly for Trackers/Sunrunners made after 1995.
All three vehicles are the same critter - especially if they came from the CAMI plant in Ontario, Canada.
I know that the softtops on 1966 and newer TracKicks are not interchangable with pre-1996 equivalents, so it might be safe to assume that the rule applies for the hardtops too.
Of course, you know what happens if you assume... ;D
I hope that this helps!
Yes it does ....Thanks so much.
the hardtops have no difference. the soft tops are interchangable as long as the mounting hardware is changed aswell. (hardware and top have to be same generation) the hardtops replace the factory soft top hardware and they mount the sameon either pre or post 95.
