ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: HugoSamurai on March 21, 2010, 12:38:06 PM
hello, know you tell me the cars that use the intake manifold that fits in the suzuki 1.6 8v? :)
most 1.3s intakes will fit
you refers to the suzukis 1.3 ou another cars? i need to know manifolds of another car brands ;)
Only Suzuki powered 1.3 and 1.6 vehicles as far as I know
up
Wildgoody has it correct. The intake will have to be from either a 1.3L or a 1.6L 8 valve.
With the 1.3L intake you can adapt it to use a variety of carburettor. Everything from Harley Davidson side drafts to Hyundai Pony carbs have been used with success.
btt i already have a 1.3 inlet in my 1.6, but i like to now more variaty of inlets ;)
You will have to cut, hack and weld together either a custom manifold
or pieces of other stock manifolds.
sorry for stealing your thread, will a 1.3 8v intake fit a 1.6 16V?
Sort off, you need to fit a plate between the head and the manifold to blank off the injector cutouts and then find some way of running the ignition. It is possible to use a Sammy dizzy but you need to reverse the direction.
You can get a new dual weber dcoe manifold on ebay. I emailed the seller and he will sell only the manifold.
