ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: smife on March 24, 2010, 10:31:12 AM
Title: 94 to 96 16v motor swap
Post by: smife on March 24, 2010, 10:31:12 AM
Will a 94 16v swap to a 96 without changing the computer? Do I only have to change the motor or is there anything else?
Title: Re: 94 to 96 16v motor swap
Post by: Drone637 on March 24, 2010, 10:40:44 AM
You have to change a few things:
Depending on which one is in better condition you will want to swap the exhaust header as well, they tend to crack between the 3rd and 4th cylinder.  Might want to take this time to pick up an after-market one along with a new clutch, water pump, timing belt, distributor o-rings, front and rear main seals.
Post by: wildgoody on March 26, 2010, 07:57:07 PM
If I read this right, you want to put a 94 16V engine into a 96 16V or 8V? I thought the 96
years all had 16V engines? if this is so, you need to change nothing but the intake manifold
and sensors just to be sure they work with the new engine
