ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: skookzuker on April 03, 2010, 07:58:47 pm
i got a samurai with a stock 1.3 motor in it. i was going wheelin one day and my motor just died on me when i was goin threw a hole. its not getting any spark. i checked the resistance on my coil and my distributer and ther both fine. i replaced the computer and that isnt the problem. im getting power to everything but im not getting any spark out of my coil. i tore apart my wireing harness to see if i can fined any bad wires and there wasnt any. im compleatly stumped on this one.
only thing I can think of that makes ANY sense is the coil on your firewall is DOA. is it original or aftermarket?
i just got a new coil for it
the coil tyhat was in it before was a msd 2 and that has a bad resistance reading so i replaced it . i have tryed 5 different coils. all good and all give me no spark
i even tryed hookin my batery right to my coil for a deffinate ground. im getting 12volts to the coil but when i crank it over it drops to 10volts. idk if that helps at all
This may sound silly to ask but did you check your coil wire? it's easy to over look
when you get frustrated >:(
yes i checked my coil wires. i have power getting to my coil and distributer. i am not getting any spark at all. HELP!!!!!!!!!!!!!!!!
You need to replace the ignitor in the distributor,
probably easier to just get a used distributor for it
i got an new used distibuter for it already. i checked the resistance in it and it meet requierments in my samurai book. i will re test it. if its good then what else could be the problems????
thats most of your problem, you're buying USED parts. buy BRAND NEW and it will probably work. used ignition parts is pretty much a gamble, it may work, it may not. you just dont know. resistance tests even dont make much of a difference to me.
i priced a new ditributer out and its 400. i know i should buy new parts and its a gamble but 400 for a part that might not be the problem is a gamble to. its fustrating
im not getting any spark out of the coil. i have power to my coil but no spark. i think my distributer is fine. i cant know its my distributer because if i dont get any spark out of the coil how will i know the distibuter is bad or good? i have to get power out of my coil first to get power to my distibuter. why am i not getting any power out of my coil if my coil is good and i got power going to my coil???????
check your primary/secondary wires going TO the coil on the vehicle harness. I'm betting you're missing something REDICULOUSLY simple. might even just be a fuse in the panel under the dash.
