ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: gearjam on April 06, 2010, 08:05:41 PM
Do all Tracker Sidekicks have the same capacity fuel tank or do the 96 to 98 hold more? Like to add some extra range if I can just bolt in a slightly larger tank.
4 door tanks are 14.5 gallons.
2 door tanks are around 11.5 gallons, IIRC.
I don't know that they changed the capacity in either one in the 96-98 years.
The 40 L (2 door) tank has different mounting points from the 60L (4door). Physically it WILL fot but you will need to re-fab the mounts.
