ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: Taimur on April 14, 2010, 06:28:01 AM
Title: Evil Twin Stick shifter
Post by: Taimur on April 14, 2010, 06:28:01 AM
During surfing I came accross with Evil Twin sticks for sami. quite impressive. I need your expert openion on how they work.
What I understand, one stick is for shifting between H and L and second is for between 2wd and 4wd. I have manual lockign hubs.
Does front shaft is disconnected when you put in 2wd low range?
thanks in advance for your expert openion.
Title: Re: Evil Twin Stick shifter
Post by: cobleeze on April 14, 2010, 09:36:24 AM
Yep!
Post by: ebewley on April 14, 2010, 10:04:43 AM
Yes, that's the best part... 2wd low range for various off-road manuevers.
I have one our our GI Jane project and aside from the inner boot, (or lack of one)  I really like it a lot!
Post by: my996duc1 on April 14, 2010, 03:33:09 PM
I was thinking about going to the twin sticks... here are the boots that I was planning on using, will they not work ??
on the t-case - https://www.rock4xfabrication.com/store/product_info.php?products_id=289&osCsid=b11216745d648e081041282f577efd2e (https://www.rock4xfabrication.com/store/product_info.php?products_id=289&osCsid=b11216745d648e081041282f577efd2e)
inside the cab -http://www.lowrangeoffroad.com/index.php/suzuki/samurai/transfer-case/twin-stick-shifter-interior-boots.html
Post by: bentparts on April 14, 2010, 04:59:37 PM
It should work, also he sells a boot kit for the top of the transfer case that is well built. I have one of his for a couple years now, no complaints.
Post by: Amilla on April 15, 2010, 10:41:36 PM
From when I have been reading, the Rock4x lower boot wont work with the Evil Twin set up.  Not enough movement within the boot, it tends to pull out of gear. But I might of been reading old literature, and something could of changed.
I just got myself an Evil Twin set up...haven't installed it yet but the product looks great!!
Amilla
Post by: rascott on April 16, 2010, 07:39:43 AM
that transfer case boot looks real nice(the sammy t/case must be a little different than mine).
i used part of a rubber glove. good for some years so far. also sewed up a cab boot that works.
the 2 wheel low is real nice- you will like it.
Post by: zuk_freak on April 16, 2010, 11:01:59 AM
is there anything like the evil twin for a sidekick?????
Post by: cj on April 17, 2010, 04:02:37 PM
The ones in my Kick were made by 37Kicker on here and they use the Rock4x4fabrication boot and I teamed them with a Dana twinstick boot for in the cab. Rock4x4 also does them too.
For my Sammi I have Rock4x4fabrication twinstcks with the same boots. I don't know why the sticks aren't listed but they are available. I got mine through Sean at Low Range.
Post by: Reddog1 on April 28, 2010, 11:41:33 AM
I am no expert, but do have the Evil Twins and an opinion.
Mostly true. The left stick is for lo, neutral, & hi. The right stick is for 2wd or 4wd.
No. You disconnect the front shaft with the right stick, which is for 2wd or 4wd. You can use lo range (left stick) in 2wd or 4wd.
You are welcome.
The Twin Sticks allow you to have a true neutral, which is great for flat towing. It allows you to use hi or lo range in 2wd or 4wd. If I am wheeling, I usually lock my hubs, put the right stick in 2wd, with the left stick in hi or lo (depending on my speed). When I need 4wd, I only need to move the right stick to 4wd. The hubs are all ready locked. Then I can move the right stick back to 2wd, without unlocking the hubs.
Wayne
