ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: SideTrackedInNY on May 19, 2010, 07:12:46 PM
Title: ????? IS THE REAR DRIVE SHAFT THE SAME LENGTH IN..........
Post by: SideTrackedInNY on May 19, 2010, 07:12:46 PM
A FOUR DOOR AUTO AS IT IS IN A 5 SPEED??????  THANKS MATTY D.
Title: Re: ????? IS THE REAR DRIVE SHAFT THE SAME LENGTH IN..........
Post by: wildgoody on May 19, 2010, 07:17:06 PM
I think it is, the T-case is bolted to the same place, and that's the
end of the trans assembly
I did a swap from 5 speed to 3 speed auto, but it was a 2 door, seems
like we used the same driveshaft there too
Post by: SideTrackedInNY on May 19, 2010, 08:13:01 PM
OK THANKS WILD .....
Post by: cj on May 19, 2010, 08:18:44 PM
3 spd auto and 5 spd manual are the same but the 4 spd auto should be shorter due to the increased length added to the auto by the overdrive.
Post by: SideTrackedInNY on May 19, 2010, 08:38:32 PM
ok thanks cj  will have to go over to my lot and measure it i guess...thanks   matty d.
Post by: Skyhiranger on May 19, 2010, 09:07:35 PM
I can tell you for sure that the driveshafts are not the same length.
Post by: SideTrackedInNY on May 19, 2010, 09:23:32 PM
thanks again guess i need not measure then....thanks matty d.
