ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: 87zukini on May 20, 2010, 05:06:05 PM
ok guys im starting my toyota axles i have my front axle but its missing the hubs not just the lockouts but also the whole hub . im wondering if the ones from an ifs truck will fit on the solid axle spindles? im going to run 5.29 gears spool rear locker front and a high pinion. plan to run a 1.6 16v with the tracker 5spd and t-case in front of the samurai t-case . anyone running this how does the samurai case hold up?
thanks for any help
mike
You can use some parts off of IFS Toyota's and widen your front end 3".
Here's a good kit if your interested.
http://www.sky-manufacturing.com/new/detaproduct.php?id=127 (http://www.sky-manufacturing.com/new/detaproduct.php?id=127)
Amilla
It will hold up just fine.My old ride was a 93 kick,5:13 geared spooled D-44's,37" pitbull rocker's,homebrew dual case with 6.5 in the samurai case...Never could break it.What you need is a good mounting system coupled bucket style and you wont have to worry.
