ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: samuride1 on May 25, 2010, 07:39:33 pm
http://forum.difflock.com/viewtopic.php?t=6804&highlight=conversion (http://forum.difflock.com/viewtopic.php?t=6804&highlight=conversion)
When you can get everything you need, pre-designed and tested for $150... the design, materials, fabrication and testing would not be worth the effort to me...
http://www.lowrangeoffroad.com/index.php/suzuki/samurai/engine-upgrade/trail-tough-1-6l-engine-adapter-kit.html (http://www.lowrangeoffroad.com/index.php/suzuki/samurai/engine-upgrade/trail-tough-1-6l-engine-adapter-kit.html)
The thread descibes how to fit the 1.6 without an adapter. Easiest method is to drill through for the bottom mounts, no design, fab or testing required. I haven't done it personally but I used to wheel with Breedsey so I've seen the conversion, its very tidy, could pass for stock.
I see what your talking about now... I thought they were fabricating their own plate ::).
Anyone else that would like to chime in????
Call me lazy, but I have enough trouble keeping my Samurai running properly without worrying about problems created by attempting to fit a 1.6 onto a Samurai transmission bellhousing without an adapter plate.
I have an Calmini plate from way back in 2000 - which might not be as good as the full-circle plates available these days - but it gets the job done.
At $150, that adds up (conservatively) to seven 4-hour days of tips from delivering pizza part time... ;)
