		ZUKIWORLD Discussion Forum => Classified Ads => Topic started by: Bigzook on June 04, 2010, 05:50:10 AM
				Hey guys I need a kick 4wd 5 speed in oregon. Cheap would be good. I have a bunch of parts off the race car I could trade or some sami parts as well.
				i have a cheap one, unfortunatly it is cheap for a reason.
				What the heck does that mean Jason?
				iIt's a little noisy. The car had 180,000 on it. What do you want it for?
				I need one for Cherry Bomb so I can run my modded T-case(thanx Joemama)
				modded t-case? isnt yours 2wd? if you want it and it will work for you, you can have it. it prolly has plenty of life left for racing, it was just a bit noisy on the road.
				I will take it! call ya tomorrow.
				ok, you do that then!
				If it's the whining that starts out in lower geard then works its wat through all but 4th gear you can fix it fairly easily.. Give me a shout G.
 Z
 Z
 it was a long time ago and we didnt run it long(bought the car that way) but i think i recall it wasnt in 4th gear onjly the others, but i thought it was more of a growl than a whine
				I had a couple of trannys do that.. One I replaced, the other I drove into the ground, then Mike told me there are a couple of bearings you can replace that will 'fix' the issue. Does not fix the tranny like a rebuild but makes it last a while longer (maybe be a perfect candidate for a race truck...)  :-\
