ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: badkat on June 10, 2010, 01:29:27 pm
just recently put clutch in i went to put oil that we caught back in wouldn't hold but half of it started running out
is the plug on side of trans the only place where you fill it or recon somebody just over filled it
thanks
anybody know
80-90w gear oil. non-synthetic GL-4. is what the factory calls for. GL-4 has been replaced with gl-5. So, GL-5. Synthetic oil has smaller particals and some say it can seep out through your seals. personal preference.
also iwent wheeling and the clutch started not disingaugeing al the way i tighting the cable till it ran out still not right
new clutch any susgesting?
check the clutch arm. the part that connects to the transmission with the cable on the bottom. make sure that isn't stripped or it slipped.
thanks for your help man!!!! i found the outer part cable was broke making it not pull the arm far anough
As for the oil coming out of the side, that means it's full. You only fill it up to the fill plug, same with the transfer case. :)
