ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: cracked91 on June 26, 2010, 04:07:42 pm
Hi all,
Im running 31" tires with SOA on my stock gearing rig, and am going to be re-gearing soon.
From the standpoint of a daily driver, and fair amounts of highway use, which would be a better idea?
Should I just buckle down and re-gear the Ring and pinion or just get the 6.5:1 gearset for the transfer case.
I have an extra t case, and was just going to do that, but people seem to think doing the diffs is a much more solid modification.
Any advice would be greatly appreciated.
The main difference between dif and t-case gearing, is that R&P gearing takes the stress load off the drivetrain at the differential. Tcase gearing takes the stress load off at the transmission output.
In terms of DD, either way is good. In terms of Offroading, I think that R&P gearing cuts down on drivetrain component stress and breakage.
I have been wrong...
Both together give you excellent crawl abilities.
I like the t-case gearing myself, but both have their place. With the amount you spend on gears for both the front and rear you can replace the transfer case gears, plus you get a low range reduction.
Ack is correct in that the gears in the diff cuts down the stress a bit as your R&P doesn't have as much torque going into it. But I have usually found that the axles are the weak point, not the u-joints and diff.
the t-case route is great because it gives you LOW reduction, and a little high reduction (back to stock). R&P will reduce everything equally. just my opinion...
play with the t-case numbers on the calc.
http://www.lowrangeoffroad.com/index.php/suzuki/samurai/transfer-case.html (http://www.lowrangeoffroad.com/index.php/suzuki/samurai/transfer-case.html)
http://www.lepayne.com/gears.html (http://www.lepayne.com/gears.html)
Just when you think a debate will break out...
Drone367 has a very good point there! Setting up a set of ring and pinions is much more difficult ( read "costly") than a transfer case regearing.
I vote a little bit of both...if you can afford it
play with the gearing calculators online and see what will work best.
Here is an article on this from TRAIL TOUGH :
http://trailtough.com/index.php?option=com_content&view=article&id=60:gears&catid=36:techinfo&Itemid=60 (http://trailtough.com/index.php?option=com_content&view=article&id=60:gears&catid=36:techinfo&Itemid=60)
I think this debate has been done a few times. I'm just to lazy to crawl the archives. :D
