ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: Missouritrailrider1 on June 30, 2010, 10:33:19 am
Title: hub/wheel questions
Post by: Missouritrailrider1 on June 30, 2010, 10:33:19 am
ok, here is the problem. i need rig doneby weekend so i can wheel it. first of all, i replaced wheel bearing and got all back together. hub spins fine until i put wheel on and tighten lugs then it wont spin?? also second question is when i install new/used hub, when i do where can i get a new circlip since im missing mine?
Title: Re: hub/wheel questions
Post by: bentparts on June 30, 2010, 04:02:46 pm
It would help if we knew what you were working on.
Post by: Missouritrailrider1 on June 30, 2010, 07:15:41 pm
srri its an 88 samurai. got wheel prob fixed but what size or where can i buy circlip?
Post by: Zukipilot on July 01, 2010, 04:16:31 am
Any NAPA store should have it.
Post by: Missouritrailrider1 on July 01, 2010, 05:49:25 am
is there a certain size or should they know it or what
Post by: Skyhiranger on July 01, 2010, 12:12:21 pm
Is the rotor binding against the brake pads?  Maybe you need to make sure the caliper is free floating, like it is supposed to be.  Sometimes they bind up and won't slide back and forth like they are supposed to.
Post by: Missouritrailrider1 on July 01, 2010, 05:21:01 pm
thats exactly what it seems to be doing, this could have been caused by fact that old wheel bearing was so trashed that wheel like tilted in at top and locked up sometimes, dunno how long they had it like that but i replaced bearing locking hub ect, it seems to get easier the moore i mess with it, i will wheel it this weekend then check up on it again see how it looks/works. i already hat zuki axles and want to go full widths on 35's but dunno much bout outboard front springs or cutting housing for spring...........
