ZUKIWORLD Discussion Forum => Classified Ads => Topic started by: yellow2000S/R on July 08, 2010, 12:28:35 pm
Title: PnP, milled 16v head
Post by: yellow2000S/R on July 08, 2010, 12:28:35 pm
Contact: PM or email me - yellow2000SR|removethispart||removethispart|@gmail.com
Price: $350+shipping
My 16v bottom end in the 96 Tracker has a bunch of scoring so I'm probably going to source a v6 to swap in for more powa.
Looking at getting $350+ shipping. I paid $100 for the head from junkyard, I've got ~4rs labor in it for PnP work, the new valve seals, and $214.xx for machine work.
I'll get pictures of the head as it sits shortly.
I port matched the intake runners to the gasket and the exhaust side to 1mm undersize of the gasket. You'll need a header for best performance cause the exhaust runners are larger then the stock cast exhaust manifold flange/runners. All bowls were blended.
The head has just over 4k miles on it since machine work which was performed at UCF Machine Shop in Carlisle PA. Work performed was mill .015" off to bump compression slightly, full valve job, replaced 1 valve, and tanked/cleaned.
I put new valve seals on during reassembly. The head will come with all of it's "internals".
Pics after PnP work prior to bead blast and machine shop work:
(http://www.endlessmotorsports.net/Gallery/Tracker/13.jpg)
(http://www.endlessmotorsports.net/Gallery/Tracker/11.jpg)
(http://www.endlessmotorsports.net/Gallery/Tracker/14.jpg)
Pics when it was fresh from UCF Machine Shop.
(http://www.endlessmotorsports.net/Gallery/Tracker/21.jpg)
(http://www.endlessmotorsports.net/Gallery/Tracker/20.jpg)
