ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: djlantis57 on July 14, 2010, 01:34:13 am
Small oil leak at my distributor. 1.6L 8v in a 90 Tracker. It's been there since I bought it and now that I'm trying to stop engine oil leaks, I might as well focus on this, too. Question is, what is there that could be leaking?
I know there is some sort of o-ring on the distributor shaft, but can't buy it anywhere. Is there also some kind of a gasket or seal for the actual distributor housing itself?
I really want to do this myself, but not too confident about timing the engine, especially since it doesn't run too well at the moment. I may just send it in to get worked on and figure out my high cold start idle at the same time. Damn demons in the engine compartment >:D
I bought a new o-ring for my distributor from Hawk Suzuki. http://www.hawksuzukiparts.com/ (http://www.hawksuzukiparts.com/)
I don't see it listed on their site so might have to give them a call.
You can also take the old one to a good autoparts store and just match
it to a new one, add a little gray silicone to the O-ring and the housing
and it will be leak free for a long time
http://www.kick-fix.com/buy-parts.html#Dizzy-rings (http://www.kick-fix.com/buy-parts.html#Dizzy-rings)
Look thru this.
Yes, there are two orings...one on the disty shaft, one between the housing and the back of the head.
That link gave great info...I'll also call Hawk to see what they got. If they got it, I'll try to get it by next week.
Getting a visual helped tons, it was linked on that page that ranger88den linked to:
http://markb.smugmug.com/gallery/4606153_GPWWw#271666242_FGJMC (http://markb.smugmug.com/gallery/4606153_GPWWw#271666242_FGJMC)
When I did my valve guide seals way back, not only did I replace the O ring, but I used a gasket sealer on the two surfaces. No leaks in 48k miles and still going strong.
some people use rtv between dist and head
I bought a new o-ring for my distributor from Hawk Suzuki. [url]http://www.hawksuzukiparts.com/[/url] ([url]http://www.hawksuzukiparts.com/[/url])
Yep, do a search of a few suzuki aftermarket companies I know a few sell them.
