ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mike5721947 on July 19, 2010, 07:37:15 PM
Title: stock rim question
Post by: mike5721947 on July 19, 2010, 07:37:15 PM
ok, i ran some borrowed 31's on a club run a couple months ago and had them on stock steel tracker rims. i thought they were 15x7 but all the info i can find says different. im wondering if it is acually the same width as my rims i have that are 15x5.5 as that opens up alot more rims to me. i have a set of 31's to throw on the truck but i need another set of rims for them as i still need to run street tires.
ive read that some dodge ram and ford truck rims fit as well, but whats the backspacing?
Title: Re: stock rim question
Post by: wildgoody on July 19, 2010, 09:11:53 PM
Yes, as long as the center hole is 105mm or 4-1/4" and the lug holes
are 5 on 5.5. As far as the backspacing the stock wheels are pretty
neutral, so probably half the rim width, but to be sure you need to
measure them on a case by case basis
Post by: Skyhiranger on July 20, 2010, 05:48:32 PM
Most ford and dodge wheels are around 3.5"-4" backspacing.  Most aftermarket wheels will be in that range too for backspacing.
Post by: BeercityTracker on July 20, 2010, 09:33:00 PM
here is a link to all the stock rims that will fit
http://www.zukiworld.com/forum/technical-discussion-beginner-repair/92-sidekick-rims/ (http://www.zukiworld.com/forum/technical-discussion-beginner-repair/92-sidekick-rims/)
Post by: beagle..t on July 25, 2010, 09:50:09 AM
i thought that center bore hole had to be 108mm to fit ,
Post by: wildgoody on July 25, 2010, 10:11:24 AM
4-1/4 inches is 108mm but the hole only has to be 105 for the front
hub to fit through, if I'm not wrong about the dimension, but I could
be wrong, I'm just going from memory
Post by: beagle..t on July 29, 2010, 05:42:04 PM
np wild you r pretty much the guru on trackkick from what i have read
Post by: wildgoody on July 29, 2010, 07:27:43 PM
Thank You, I'm wrong sometimes, but if someone says other
from what I thought the answer is, I go look it up to make sure
I got it right, still learning every day  ;)
