ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: moedway on July 28, 2010, 02:30:36 pm
i can get a set oif 15 steel wheels with 4inch back spacing. my concerns is the centere hub hole being to large I think its 108 the new wheels are 109.5 will this beok to run on the highway. or i cAN GET 16INCH wheels what tire size get 33inchs
as long as the lug pattern is the same i dont think it makes a difference.
the problem with finding wheels is the center bore hole which should be 108 mm anything bigger should b fine just as long as they r 5x5.5
