ZUKIWORLD Discussion Forum => Classified Ads => Topic started by: DaddyDave on August 17, 2010, 10:03:38 PM
Off of a 89 Tracker - all parts used
20,000 miles on suspension
All parts plus shipping from So Cal
UPDATED 9/24 - PICS AVAILABLE FOR ALL PARTS - SEND PM
CALMINI 3" front control arms w/ball joints and new control arm bushing kit - SOLD
CALMINI strut extension (3" tall) - SOLD
CALMINI 3" Diff Drop Set (all 3) - SOLD
Factory Aluminum Front Diff Housing/3rd - SOLD
Factory Drivers Side Axle Shaft - $20obo
CALMINI Steering Stabilizer w/Factory steering links and New Idler Arm - SOLD
Tracker Windshield Visors - No Tears - $15obo
Factory Tracker Spindle/Hub Assemby (Pass & Driver available) w/rotors - $40obo per side
Stock Tracker rear axles 26 spline, no hardware - $30obo
CALMINI V-bar and Trailing arms w/diff Mount and heim. good bushings - sold together - SOLD
3/16" Plate Steel Rear Bumper w/brackets for 3" body lift - $150obo
Samurai Front Driveshaft w/ Two CALMINI 3/4" DLS - $35obo
Samurai Rear Driveshaft w/ One CALMINI 1" DLS - $35obo
PM for ship quote and questions
whats missing to make this a complet kit? PM sent
Geogre
I'll check for the differential drop brackets today. Those would be the only parts needed to complete the front kit.
Also have both drive axles. One is definitely used and the other has about 5,000 miles on it.
wow...seem higher than balls on a giraffe for a incomplete lift ???
Based on what?
The arms aren't sold sep. from the kit and they have the bushings and ball joints. How about not posting if you're not interested...fair?
yes daddy. :P
I can simply see no reason to make comments in the Classified section on parts you do not have an interest in. Take it elsewhere
You are actually missing a few parts! Axle drop brackets, strut spacers, the extended rear trailing arms, the adjustable v-bar, that is what you need to complete this kit, also do you have all 4 springs? If you are missing all those parts it will be pricey to complete!
myk dee
That is correct, that is why I only listed the parts that were available.
Front springs have already been shipped. No rear components at this time.
Updated with more parts and lower prices...PM if interested. Need this stuff to go!
BUMP! IMHO that is a good price on the arms WITH new bushings and Diff drop brackets too. They won't fit my 2nd gen, so I can't jump on this deal but I know I will have to pay around $300 for 2 new OEM a-arms and 4 new a-arm bushings and still end up with non-replaceable ball joints and less clearance.
a new bushing kit is $30 right off the top from CALMINI and the ball joints are still usable.
