ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: explosivo on June 21, 2004, 05:32:29 PM
How badly do auto hubs suck? Would it be worthwhile to nab the hubs off the parts tracker to stick on the new $100 one (which has auto's)? Do auto hubs mess stuff up?
Auto Hubs are for your grandma, when
she starts slipping in the snow and don't
want to get out. Throw those things as far
as you can, and put manuals on, then get
out and lock your hubs before the snow is
a problem :)
I've run with my hubs locked on the other Tracker since winter... is there any negative effects of leaving them locked?
A little gas mileage. That's it.
Yes, auto hubs if used heavily, will break front ring and pinions, aluminum stuff, and maybe more if you are into it heavy at the time. Ask Heather. :D
Auto hubs are going into the junk pile tomorrow :)
Anyone check to see if the drive flanges of the Vitara model work on the Trackick versions?
This makes the front axle rotate continuously, but there is no hubs to lock, no auto hubs unlocking, just pull the t-case lever and go....
I ran the manual hubs from my kick on my Grand Vitara, so it should work the other way around.
Mac
The GV V6 is a whole different kettle of fish, you fit the whole axle or the third member but you can't mix and match the R&Ps. I'm currently having a steel GV axle rebuilt to go in my truck. The 5:83 R&Ps have to be fitted into the Track/Kick carrier and then the carrier fitted into the third mamber, its not possible to retain the GVs freewheeling mechanism
I love my auto hubs. Never broke one yet. just dont do neutral drops in 4low. I also run 33x12.5s and gets a lot of abuse.
I would agree with this there is an actuator that slides back and forth in the housing to engage the axle, that is what makes it free wheel, but given that on the GV the front axle is turning continuasly and by running manual hubs it will save a ton of fuel, but the hubs them self from an gv are the same setup as an autohub sidekick.
Yup they suck. lol
It's not the hubs that break.
It's the Alum other parts.
Time will tell.
~Nate
if it's the other parts that break, then it's not fair to tell him that auto hubs suck. I personbally am totally lazy and like the fact that I dont have to get out and turn them on. The only downfall I have is when I'm stuck with one wheel in the air, and trying to rock the truck, they disengage if you're not careful
Yes, it fits. Infact in other countries you can find a Kick with factory drive flanges instead of auto/manual hubs.
The thing is, the auto hubs CAUSE aluminum and other parts to break. I've seen it with Heathers truck with no locker and small tires, because they have the bad habit of unlocking when you back up to get another run at something and when you have the go pedal applied, the hub will realize that it needs to lock, and then...... BOOM!!!! Something broke.
You're right, it's not the hubs fault that the aluminum and other stuff broke with small tires. The aluminum is a bad weak spot, it breaks even with manual hubs. But it lasts longer with manuals. The autos are just too inconsistant.
Why do the auto hubs unlock in reverse? I thought I kept feeling something in reverse when I was weeling the X a few weeks ago. What are U suppose to do backing up a hill or trying to back out of a mud hole to get another run.
Just the unlocking part would be enough for me to say, YES they suck.
OK I understand what you are doing now, but does it make a noticeable difference? I can't say I've noticed much difference with my car hubs locked or not on the highway. I don't take that much notice of fuel consumption though - if I did it might depress me ::) I'm only running with the (manual) hubs locked cos one of them broke. They are OE and have a rather weak looking plastic locking ring .
auto locking hub unlock when the driveshaft stops spinning (out of gear) and the tires are rolling backwards. It does not disengage when you are wheeling backwards up a hill.
.... when you are wheeling backwards up a hill.
You break alum diffs.
HEHE!!!!
;D
;D
LOL ;D ;D
Now I'm told the 5:83 R&Ps will fit in the GV V6 axle as long as you use the 26 spline driveshafts. I just another front diff to get the 26 spline gears :'( :'( Now I'm told I have a 12 bolt rear and I need a 10 bolt, more expense :'( :'(
