ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: SiKiD_01 on June 02, 2005, 04:53:22 PM
any pics, links, info on the kicker 3?
thanks
steve
http://www.granitepath.com/friends/kd7hcg/pictures/SAS/OTTstuff/catalog%20data/25.html
that is heathers
how does the kicker 3 work again?
here is the link.
http://www.ottindustries.com/kicker3.htm
thanks guys.
now if only i could get it in australia, i'd be set.
OTT say you need to send them both transfers. man, i think freight for both transfers to the states would cost more than the kicker 3 itself. let alone sending it back to oz.
its all poo.
No they changed it, you only need to send in the track kick x-fer case, you keep the samurai trans fer case.
i am about to start making my own twin t case set up. using a tracker t box mated to a sammy one.
a few people here in oz are doing a dual case set up. only they are doing it in LWB zooks wheres theres heaps of room to keep going back.
i have a swb, and doubt it will be an easy task to get twin transfers under. wild weasel has done this, but extended wheel base and solid axles, what more could you want.
i'm also not too keen on the intermediate shaft, like in a normal sammy set up with a divorced transfer. i would much rather have a kicker set up, where the transfers and gear box are all bolted together solid.
anyway, thanks for the info guys.
Talk to GRVIT. He lives in Greece and has a SWB. He's going SAS though. But, he did order a Kicker 3 from OTT that's being shipped to greece. OTT was nice enough to find a couple of transfer cases for him in canada and just let him buy them through them. :)
Also, just know that you need to be patient with OTT. It takes a little while to get a Kicker 3. They're a 3 man shop I think, and have loads to do.
I don't think that the additional length a kicker3 adds would be an issue in a SWB.
Its marked for Sammy people as a direct bolt on for people who've done a 1.6v conversion. (stock Sammy t-case location)
