ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: RifleRide on June 21, 2004, 09:13:34 AM
Title: Skip in Kick
Post by: RifleRide on June 21, 2004, 09:13:34 AM
I developed a skip in my 89 kick and it was diagnosed with low compression in #4 cylinder.  Mechanic suggested a valve adjustment might be in order or possible worse problems.  I removed the valve cover and attempted to adjust what seemed to be some over tight valves.  Skip is gone, but not sure I got the right clearance for adjustment.  Heard some rumors that owner manuel not exactly right on their info.  Anyone know the gap for 1.6 intake and exhaust valves?
Title: Re: Skip in Kick
Post by: explosivo on June 21, 2004, 09:32:41 AM
It tells the clearances (hot and cold) on one of the stickers inside the hood, IIRC.
Post by: wildgoody on June 21, 2004, 11:51:22 AM
.006 intake .008 exhaust (inches)
in mm I don't know, one thing that
caused me problems was that Zuke Valves
tighten as they wear, which creates burned
valves, and a valve job for me at 200,000
until then the motor had never been apart.
Good Luck
Post by: chopper on June 21, 2004, 07:32:55 PM
wow that is so correct on the burn valves occuring, i jsut rebuilt my topend at 230,000 and now she purrs like a kitten, pretty easy job too.
Post by: RifleRide on June 21, 2004, 11:50:46 PM
Thanks guys!!!  You just proved, you can't go by the numbers in the chilton's "maybe its like this" book.
