ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: ridgerat4x4 on September 20, 2010, 07:38:26 PM
where can i find out more info about this setup i tried the search didnt help a lot
http://www.ottindustries.com/kicker2.htm (http://www.ottindustries.com/kicker2.htm)
Google search kicker3
Enjoy,
good luck.... I talked to the new owners a couple months ago and they were talking about dropping the kicker line. the new owners are not off-roaders and said "theres not enough profit" from us off-road degenerates. call them, talk 'em in to keeping them.
What are they going to sell if they drop the off road degenerate stuff ???
they are a hot rod & Harley type shop.(big money type stuff) I cant remember there name right now. they are keeping the OTT web site for now but if you call they will give you there real web address. when I talked too them last they had one kicker4 box with out the shifter riser (only work with auto) and no plans for building more. I hope they have changed there minds!
Save yourself some headache and do the RingR. I wish I did. There's a ton more aftermarket support for toyota gearing. My kicker 2 took 9 months to show up. It sounds already like the new owners will have the same crappy customer support as the old owners (if not worse). That could seriously F your entire build.
I was going to get the Kicker 3 so I looked into it and it turns out that the new company is only dropping the kicker 1! They will still make 2,3,and4. I also understand that they are turning them out much quicker than before. But they have raised the prices... surprise surprise.
what was there turn around time on the kicker three setup now, just curious, i was going to order in the middle of there buy out and didn't want to wait so i built my own and works great, guess i should use to my advantage that i run run a cnc machine every day sure helps when you need stuff built
called OTT the other day. They still are unsure about the kick3. Told me to call them at the end of Nov. New price is $1200 and did not want a core. I may just go with the undertaker.
i just got all my machine work done to build my own i building two others thinking i will have mine in this weekend in the new sami project i wanting to take it out the 19 or 20 and do some wheeling i built enough parts to build the two other and welded up another case and machine the out put shaft on trans so i can sell them if some one might be interested
