ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: elf on September 29, 2010, 06:20:24 pm
Lost the bolt on top of my transmission and now it leaks oil when at angles. The bolt is right behind the plug for reverse lights. Any one know what size bolt is so I can replace it?
Are you talking about the hole that points towards the drivers side? If so, no bolt goes in there, it is a rubber plug. Just find something to stick in there and silicone it up, to seal it, and it should be fine.
Thanks for the info will fix tonight thanks again!!
