ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: airmanwilliams on October 11, 2010, 12:37:17 pm
Title: unknown sensor question
Post by: airmanwilliams on October 11, 2010, 12:37:17 pm
Ok so I just sprayed off my transmission alittle and found a sensor that isnt connected to anything. Can anyone tell me what it is and if its important?
Title: Re: unknown sensor question
Post by: ack on October 11, 2010, 01:58:26 pm
I believe that is the fifth gear switch.  It works with the ECU to adjust ignition/fuel delivery for optimum mileage.
otherwise it is the transmission's reverse gear switch - which turns on the backup lights in reverse gear.
Post by: airmanwilliams on October 11, 2010, 02:04:56 pm
thanks for the help my reverse lights dont work so that may be it. I have two wire from a connector on the harness that arent connected to anything and i thought it just went to the lights so thank you for the info I will connect the wires to that then.
