ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: 95XL7 on June 12, 2004, 09:27:12 AM
Title: Ring & Pinion sizes??
Post by: 95XL7 on June 12, 2004, 09:27:12 AM
Are Samurai and Sidekick ring&pinions the same size?? Just wondering because i see a place that sells 5.38 ratio gears and that would be perfect for my rig.
Title: Re: Ring & Pinion sizes??
Post by: Charlie on June 12, 2004, 12:03:12 PM
Those gears fit the front but the rears different, it's next to impossible to find to find those ratios for the rear.
Charlie
Post by: idaholwb on June 12, 2004, 04:48:51 PM
 Front and rear sammy and front kick and GV front are all a 6.925" ring gear. The rear of a kick and GV, not XL-7, are a 7.5" ring gear. From what I understand, the XL-7 uses an 8" or larger rear pinion gear.
Does that help everyones questions? If you need it, I can give all the gear options for all of the above.....?
Sammy........3.73 or 3.90(lwb and pickup)
Kick.............4.30, 4.62, 5.12, 5.38, and the rare 5.62(89 only, 1.3 kick 2 door, only)
GV...............4.10 and 4.88
XL-7............5.12, not sure about other ratios.
How's that? ;D
Post by: TITAN on June 12, 2004, 04:56:26 PM
your just the gear exoert now arent ya idaho? lol no insult just laughing at my ridelin inspired joke...
Post by: 95XL7 on June 12, 2004, 05:37:48 PM
How's that? ;D
So what years and model kicks came with 5.38's??
I seen some on carpart.com from a 90 or 91 4 door that said they were 5.38's but i thought it might be a typo.
I will definitly be looking for those gears now.
Post by: jagular7 on June 13, 2004, 03:31:34 PM
How's that? ;D
Other ratio for -7's is the 4.30 (for the 5-sp).
Post by: Gear on June 13, 2004, 08:51:39 PM
to add to this, i just pulled apart my rear diff in a 2003 Manual GV the crown wheel is 8.5"  and i'm sure the diff ratios are 4.3's
Jeffrey
Post by: Zukipilot on June 13, 2004, 10:47:26 PM
There were a limited number of 89 Kicks that came out with the 1.3L motor. That is where you will find the 5.38's
Post by: blacknight on June 14, 2004, 05:40:49 AM
Jeffrey
Is it 10 bolts??? Also could you take some pics.
George
Post by: jagular7 on June 14, 2004, 07:07:21 AM
George
George, I have a spare drop out center section with the 5.13's for the rear of a '7. Let me know what info you need?
Post by: blacknight on June 14, 2004, 11:50:11 AM
Trying to find out if its the same as a GM 8.5 10 bolt.  If so you could get a locker, arb's ect.....
George
Post by: 95XL7 on June 17, 2004, 10:49:51 AM
I checked with carpart.com and all i can find in 5.38 is the front? What did they use in the rear? Also see the 1.3lts are 5.63 not 5.38
http://www.car-part.com/
Post by: wildgoody on June 17, 2004, 12:20:12 PM
Idaho LWB forgot the 5.83 Calmini gear
that is available for the kick front and rear
