ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: c3006 on October 13, 2010, 02:53:09 pm
Title: EFI and Carb use the same head??
Post by: c3006 on October 13, 2010, 02:53:09 pm
I have a 92 Sami with a 1.3 with EFI. I brought a 1.3 out of a 87 with a carb. I want to swap the long block off the carb motor into my sami but use my EFI instead of the carb. Am I gonna run into a passel of trouble with this or should it just be a direct swap?   Thanks  c
Title: Re: EFI and Carb use the same head??
Post by: Skyhiranger on October 13, 2010, 05:32:52 pm
It will work fine.  The only 2 differences between carbed and EFI heads....the EFI cam doesn't have a lobe for the fuel pump and the EFI has a block off plate over the fuel pump hole (it can be removed, so the fuel pump can be put on).
Post by: c3006 on October 13, 2010, 06:20:16 pm
Thank You  ;)   thats what I needed to know
