ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: alpineman on October 25, 2010, 09:06:22 am
Title: 1.3 0r 1.6L in Samurai?
Post by: alpineman on October 25, 2010, 09:06:22 am
I'm looking at a Samurai 1988, owner is not sure if the motor is a 1.3 or 1.6L is there a way to tell which motor is in it? I have attached a picture not sure if this will help or not?
Title: Re: 1.3 0r 1.6L in Samurai?
Post by: Rhinoman on October 25, 2010, 10:12:39 am
Take a look at the block on the (US) driver's side, near the bellhousing it will say G13 or G16.
Post by: Drone637 on October 25, 2010, 03:10:16 pm
I know it's not a 1.6l 16v.  Unfortunently I think the 1.6L 8v and the 1.3L have a similar looking valve cover.
Post by: Skyhiranger on October 25, 2010, 09:49:24 pm
Yep, that is the most positive way to tell.  Since it could be a 1.6 with a 1.3 intake and carb setup on it.
The 1.3 will say either 1298 or 1324 back by the bellhousing.
The 1.6 will say 1590 back by the bellhousing.
Post by: fordguy79 on October 26, 2010, 08:30:28 pm
stock 5 speed would need adapter plate to 1.6 ???
Post by: Rhinoman on October 27, 2010, 08:58:33 am
Not if the block has been drilled and tapped.
Post by: wildgoody on October 27, 2010, 09:06:09 am
You can do that? Why doesn't someone make 1.6 blocks for Samurai install
that don't need a plate instead, sounds like a better idea to me
Post by: Skyhiranger on October 28, 2010, 10:07:42 am
Probably because it is cheaper and easier to make the adapter plate.
