ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: camokick93 on October 25, 2010, 05:44:59 PM
Title: T.CASE KEEPS POPPING OUT OF 4 LOW.
Post by: camokick93 on October 25, 2010, 05:44:59 PM
Hi all.My kick's t.case keeps popping out of 4 low when the going gets though while off roading,any ideas? Shifter sheet ??
Title: Re: T.CASE KEEPS POPPING OUT OF 4 LOW.
Post by: wildgoody on October 25, 2010, 08:20:38 PM
I had the same problem, turned out to be worn shifter
dogs in the front of the t-case due to low oil level  :(
I saw the damage when I installed the low range gears
but I also had another case so I used the parts from that
Post by: Drone637 on October 26, 2010, 10:35:12 AM
I had an issue with slightly tweaked t-case mounts allowing the shifter to hit the body.  Pull your rubber cover off and see what the clearance is like.  Nothing like jumping to neutral while climbing some rocks.  :D
Also check the shifter sheet.  It is a pretty cheap part to replace so one of the best things to swap out if you haven't done it before.
Post by: camokick93 on October 26, 2010, 06:40:11 PM
Hi every one,thanks guy's,Wild,what do you wean by dogs? My shifter looks ok,cant see any particular wear.
Hi Drone,well,the shifter does'nt touch the body,but I find the big boot inside the cab very stiff,seems to pull on the lever
a little,what about the spring on top of the ball of the shift rod,I checked it it's not broken but maybe find a little stronger
spring,would make it harder to move out of gear.I will get a new shifter sheet and try it out.
I'll keep you guys posted.
Post by: Drone637 on October 26, 2010, 07:28:28 PM
Do you have a body lift by chance?
Post by: wildgoody on October 26, 2010, 10:04:22 PM
The dogs are the parts that lock the gears to the shaft, shifting
you into 4 low or 2 high
Post by: brenzuk on October 28, 2010, 12:27:46 PM
Mine did this after the body lift.  I bent my shifter, turned the boot around, and considered trimming a little (1/4 inch) from the bottom of my shift knob.  Never had to trim the shift knob though.
Post by: camokick93 on October 28, 2010, 04:19:35 PM
Hi,I have no body lift on my kick,I'm pretty sure the internals of the case are not worn out,every thing looked fine when I did
the 4.24 low mod...but then again.
Yes maybe try to bend the shift lever a little bit and I'll order a shifter sheet and see what happens.
Thanks dudes,I'm open to suggestions
Post by: wildgoody on October 28, 2010, 09:50:44 PM
If you don't have the good and worn parts side by side
you really will not notice that the one is bad
