ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: FireCkrEd on October 29, 2010, 06:13:04 pm
Title: Oh no I think I have a problem....
Post by: FireCkrEd on October 29, 2010, 06:13:04 pm
    On the way home yesterday from work my 93 4 door auto trans Sidekick started to miss and the overdrive lite on the dash was flashing. I stuck it into neutral and reved it and it seemed ok so I dropped it into gear and limped it into a parking spot across the street. I shut it off and popped the hood thinking I broke a belt and I looked and all the belts are ok. I jumped back in and started it and everything seemed ok, no lite and no miss. So I drove the two blocks home and it did it again ! Has anyone else ever had something like this happen ?
                Ed
Title: Re: Oh no I think I have a problem....
Post by: wildgoody on October 29, 2010, 09:04:15 pm
What engine?
Post by: FireCkrEd on October 30, 2010, 09:02:42 pm
16 valve
Post by: wildgoody on October 30, 2010, 09:17:15 pm
You might have a bad crank position sensor, it's located in the
oil pump housing and in the U shaped section at the front of the
engine, clean it from any dirt or oil, and see if the connector is
clean and not damaged
Post by: Drone637 on October 31, 2010, 11:14:21 am
I thought the position sensor was in the back of the engine on the odbc I 16 valve engines.
Post by: fordguy79 on November 02, 2010, 07:43:38 am
I didn,t know obd1 16v had one at all i didn't see one when i put my motor in ???
Post by: fordem on November 02, 2010, 12:32:34 pm
How that work?  You have to send a structured query to know what position the crank is in ?  ;)
Post by: Drone637 on November 02, 2010, 01:42:10 pm
I thought they used a camshaft position sensor on the distributor.  I don't know much about the 95's though, just that the don't have one on the oil pan like the 96's.  :)
