ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: SNJSamurai on November 04, 2010, 11:16:52 AM
Title: Best fuel regulator for a 1.6 swap
Post by: SNJSamurai on November 04, 2010, 11:16:52 AM
So I have my electric pump installed, motor is about to go in and I forgot I need a fuel regulator!
I found a holly carb regulator for cheap one is for 1-4 psi and the other is 4.5 to 9 psi. I am using the 1.3 carb. I tried searching for it on the forums but no luck. Im not set on the holly one so if you guys know of a cheap one and works good, let me know.
-Bob
Title: Re: Best fuel regulator for a 1.6 swap
Post by: wildgoody on November 04, 2010, 06:06:37 PM
Ya, you want 2-3 PSI so use the Holley regulator
and call it good
Post by: SNJSamurai on November 04, 2010, 09:35:20 PM
