ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: ogibson on December 23, 2010, 03:11:35 PM
Title: front end issue need help!!!!!
Post by: ogibson on December 23, 2010, 03:11:35 PM
every time i turn my truck hps like its in 4wd or somethin it a 1987 zuk with 5:13 gears and idk if thats whats causing it or what i battle it on the road it swerves alot and i just noticed that when you have the steering wheel turned strait one tire is straight and the other tire is slightly off what causes this and how can it be fixed somebody help me-thx
Title: Re: front end issue need help!!!!!
Post by: wildgoody on December 23, 2010, 07:17:31 PM
You need an alignment, you should be able to find a shop that can do it for about $50
Post by: ogibson on December 27, 2010, 11:48:31 AM
i think it needs more than that is pops and and makes a noise when i turn and one day i put it in 4wd and locked the hubs and it made a loud grindeing noise im thinking i might need a new cv half shaft idk
Post by: bentparts on December 28, 2010, 04:40:04 AM
Did you just get this Sammy? Sounds like it may have a locker in it. Definitely get an alignment though, and don't run it in 4wd on dry pavement!
Post by: wildgoody on December 28, 2010, 08:23:23 AM
Or one of the hubs is not working right, not engaging or dis-engaging
Post by: BRD HNTR on December 28, 2010, 08:25:39 AM
Sounds like at least two problems.
Steering:  Check to see if your tie-rod (connecting between both front hubs) is bent.  It can be mostly straightened if proper force is applied.  You can loosen nuts on the adjusters on tie rod and adjust the wheel alignment close by measuring distances between front and back of wheels/tires (from same spot).  They should be almost the same.  Only use home done alignments for off road use. Then as Wild stated get an alignment.
Hopping:  If it is hopping (and popping) when turning sharp in 2WD, and probably clicking when turning in reverse, it sounds like you have a locker in the rear.  This is somewhat normal behavior of lockers.  As light as Sammy's/Kickers are sometimes they hold locked until tires (turning different distances) have built up significant torque in axles against each other in the differential Locker and it unloads (allowing vehicle to lurch forward), where it again starts binding up.  This action is worse in a poorly adjusted differential with too much play.
Loud grinding noise in 4WD:  Need more vehicle information.  Does not sound normal.
