ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: JDMCRX on June 07, 2004, 10:48:52 AM
Im gonna order the rear Lock Rite but what all is needed to install it bearings? clips seals. I have 2 new rear wheel bearing im going to be instaliing and the rear axle seals.
Well on a SideKick, you just need the
locker kit, use the stock sidegears and
have fun.
Gear oil, that's what else you need, the
bearings and seals need to be pressed off
Ok coo whats it like in the bush and in the snow?
Take it easy in the snow, bush it's great,
let's you get stuck in places so remote
nobody can get you out, unless they have
a locker too ;)
yep,lockrights will help you into some real sticky situations.read the manual and follow the fitting instructions to the letter and they go in ok.
i love lockrights!! ;D
Im just wondering in the snow last year i found the 2 doro very unstable
just drive sensibly in bad weather conditions and you wil be ok.
i have seen posts from people who say lockrights are bad in snow and ice but ive never had a problem.
i just order one i will put it in this weekend. i have detroits in my K-5 Blazer on 42" boggers. when it gets stuck it takes both my 12000 lbs winchs front and rear to get it out. that is one reason i love zuks because (IF)it does get stuck 3 good size guys and a hilift will get u out. Don't have to worry about ice in southwest louisiana.
Your going to need a slide hammer to pull the axels out of the side gears.
Make sure you read the install directions carefully and take your time.
The way they have you set up the locker eliminates the need to reset your R&P backlash. If you’re careful.
why do i keep hearing about 42 in boggers and have never seen a set???
stu
stu
i dunno maybe because that will give u something else to make an aimless post about???
