ZUKIWORLD Discussion Forum => Technical Discussion - Performance / Modify => Topic started by: mojoincolorado on January 31, 2011, 07:54:57 PM
Title: Passenger side axle pops out of the front differential
Post by: mojoincolorado on January 31, 2011, 07:54:57 PM
Well, I have a 98 Tracker, 2 door, 185000 miles, 5 spd, 2" calmini lift (since 50,000 miles) and 235 x 15's on 7" wheels (all since 50,000 miles).
A few weeks ago, had the right (passenger) side axle pop out of the differential while climbing my way through a modest sized rock pile.  Got home, tested it straight on to a dirt face.  All seemed well (tires slipping).  Ran in circles, got the axle to do it again when turning right.  Figured out what was happening (the axle was very slightly extended from the drifferential when at rest).
Pulled the axle, determined the likely problem, as the last 1/4 ~ 1/2" of splines were wiped off and smooth.
Took a GV front diff and a (supposed) 5:12 Trackick diff to get it set up (been saving them for this at least 3 years), as I figured the right side gear was likely damaged (and certainly wasn't going to be clean, with all those spline bits in there).  Ended up the aluminum unit had 4.62 (or so) gears in ot, so I took my origianl front diff to the shop for the gears.
Installed it, along with an axle from the junkyard (well, the inner cv, the junkyard one's boots were starting to crack).  Then tested it.  Same thing.
Took it back to the shop, who wanted to see it all installed.  They suggested that I should replace the inner snap ring every time an axle is replaced.  I let them do it, as I had no time.  They tested it similarly, in circles, dirt and asphalt.  All was supposedly well.
Finally had time to test it.  At zero degrees and snowing.  Two things:  Now I have significant gear whine with just the hubs locked (should I expect this to 'break in'?), and the darn thing is popping out while going straight (in 4wd) -- though not fast like before (not quite what I call an improvement).  I am going to call them tomorrow.  Wondering if anyone else is familiar with this problem (popping out axles).
Thanks!
Title: Re: Passenger side axle pops out of the front differential
Post by: Zukipilot on February 01, 2011, 05:20:04 AM
I had a similar problem when I had 'a little extra wheel travel' out of my calmini 3" kit (from improper instalation). More often the inner CV would pull past the retainer clip in the cup. But after replacing one of those issues, mine was poping out like yours.... due to the inner snap ring 1- not being replaced, then 2- being improperly installed, 3- not being properly installed again  :P then I got it right... and it was back to the CV pulling out of the inner cup. After that I started bugging Calmini and realized what I did wrong (did not flip my upper strut mount back to norm when installing the spacer that comes with the 3" kit).
Your axle should be difficult to pop in and then need something prying on it for it to come back out.... Is it a tight fit? If you can remove it by hand, something's not right.
Post by: mojoincolorado on February 01, 2011, 08:29:04 AM
I've been looking on line and can't find any particular listing for the circlips.  Going to call around locally.  Also going to see if I can find out if the inner cv joint is different for the GV diff (don't see it being so, but worth finding out).
Might luck out!
Post by: fordem on February 01, 2011, 11:20:29 AM
I think the snap rings come in the boot kit - at least I got them when I bought an SGP boot kit for my 2.0 Grand Vitara.
Post by: mojoincolorado on February 06, 2011, 06:26:18 PM
Well, took the inner cv apart, decided to try the cage assembly installed in reveres (maybe more angle).  Opened the retaining spring up a bit, no change.  Still pops out in 4wd.
Arrggh!
Not apparent movement laterally in anything (even took the strut off of the hub/carrier assembly).  The strut seems good (OME) and no feeling the upper mount is loose (worn out).
Really starting to feel dumb here.  Can only think that MAYBE the whole gear cluster got moved to the GV carrier -- bad side gear???  Reaching here, I know.
Post by: mojoincolorado on March 08, 2011, 09:47:32 PM
Alright, back to the top.
Updates:
Shop couldn't figure out what is happening and almost subtley point at the lift kit (after 130,000 miles).  There only suggestion is new side gears.  Which is not unreasonable, but another $700 is just a bit more than my wallet wants to do.
So, off to the junk yard I bought a front diff out of a clean very stock 4 door.  Problem is that diff assembly has the same issue:
As you go forward (straight line) the truck steers right until the stress releases (along with a large 'clunk' -- not unlike a very large cv joint, but much slower) and the pressure on the steering releases.  Followed by a modest build up until it does it again.  A bit unnerving on snow and ice packed roads.
In a sharp turn on the pad in from of my shop (to the right) it pops regularly, seeming to come from the diff.  I don't see the 1/2 shaft popping out of the diff (from 10-20' away anyhow).  I put it on 4 jack stands and ran it in 4x4 and had my wife steer it both ways to watch for any strange behavior -- not stress on the front, so only limited data.
I am trying to think out of the box and think of a contributing factor, like ring & pinion putting certain stresses out (ie, in 2x4 on soft ground one rear tire tends to get more torque on it and spin).  Or I had a bad cardin (double u joint CV) on an F350 that went bad.  Seemed like the noise and problem only happened when the right front hub was locked -- it turned the drive shaft more than the left front, which then made vibrations.
Maybe I can raise the rear tires in the air and drive it on the front axle only (in low range) and see what's going on.
Anybody in Denver/Colorado Springs area curious to try out the GV diff assy?  I need a sanity test!
Post by: bentparts on March 09, 2011, 06:27:41 AM
Are you absolutley sure the gear ratios are the same front and rear?
Post by: BRD HNTR on March 09, 2011, 06:49:32 AM
Are you running same size tires/wheels on the front?  Not using the spare?  That clunking almost sounds like a locker unloading.
Post by: mojoincolorado on March 09, 2011, 09:33:27 PM
I pulled the diff out of a 97 (or 98) manual trans truck.  Low option model.  But, the same results as the other two diffs.
Same tires/rims (not moved).  I even swapped the hubs left<>right.  Didn't expect any differences, but only took 5 minutes.
Keep teh ideas coming, as I am fresh out!
Post by: bentparts on March 10, 2011, 04:16:01 AM
I know this a long shot, but is it possible for you to post up some good pics of you front end lift and diff setup?
Post by: BRD HNTR on March 10, 2011, 08:53:08 AM
Arrggh!
Did you inspect the outer CV?  I know they don't (at least to me) seem to break often as the inner's, but we are running on long shots now.
Post by: SnoFalls on March 10, 2011, 09:06:07 AM
You should check the ratio of the rear diff. It's a 98 5spd so should have been 5.12 stock but you also said "Ended up the aluminum unit had 4.62 (or so) gears". Perhaps some PO put in taller diffs?
I'm also wondering if perhaps you have a bad A-arm bushing. would explain "clunking" and could provide just enough extra movement to possibly dislodge the inner cv stub.
Post by: mojoincolorado on March 10, 2011, 10:22:32 AM
I guess I have confused the issue:  the original gearing is 5.12 (still is).  The two diffs I had on hand were meant to be combined at some date into one; the aluminum unit was supposed to be 5.12, but was a 4.62:1 r&p.
Hence the original diff r&p had to be used when I used the iron 3rd member. I had hoped that the tech doing the work also did not use the original side gears, but he did.  So not as thorough a change as I had hoped (always a question when some old parts are being used as well).
I replaced the a arm bushings a year or so ago when I was freshening up the steering (which is still sloppy -- one more part to find -- the center link).  The old bushing was fine, but cheap enough set of bushings from calmini, and I wanted to have thoroughly gone through the basics on it.
More ideas please!
Post by: goodyz on March 17, 2011, 09:49:59 AM
When you pull the CV shaft out of the diff, look in there with a flash light and see if your side gear is messed up.
Post by: mojoincolorado on March 26, 2011, 12:15:59 AM
I did take a cv stub and inserted it in both the steel diff (old r & p and side gears) and then into the Vitara/GV gears.  Much harder to pull out of the Vit/GV gears.
Anyone have any instructions on taking off the side gears and replacing them?  I figure the Vit/GV side gears can be swapped in.  Looks to me like they are retained with a screw in retainer that uses large pin spanners.
Post by: mojoincolorado on October 09, 2011, 10:13:36 PM
Ok, belated posting of "The Findings", or, how to not follow a red herring.
Originally I had a "pop' sound and saw my passenger side 1/2 shaft pop out of the diff.
I attempted to fix what seemed to be a problem (likely coming down the pike, but this issue had yet to arrive at the station).  Red herring alert.  Had the diff rebuilt into a cast iron 3rd member and housing (GV stuff).  The shop somehow kept leaving the known bad side gear in the right side.  Sigh.
Ultimately I picked up a used carrier assy sans the r&p.  And a spare set of 1/2 shafts.
Had a mechanic friend take pity on me and swap out the side gear (and also did a much better job than did the 'professionals' at setting the r & p mesh, as when they did it it whined, now back to the original 'silent' diff).
He and a buddy did the work at my shop, then we watched as the 1/2 shaft popped out (one of us drove it on a circle and the others observed).  The buddy couldn't believe it and asked if I had another 1/2 shaft (after I swapped the hubs around to prove they weren't the culprit).  I removed the drivers side inner cv mounting bolts.
And knew immediately what was wrong.   :o
The CV boot was stiff enough that it was holding the cv joint together when it was not forcing itself apart (as it was doing while in 4wd).  Darn!  Lots of time and effort for a pretty simple problem.  What happened?  The locking ring had popped out and the slots the rollers rode in had worn a bit in a tapered fashion.  Under torque the joint would move a bit apart and the rollers would pop out, transmitting the "pop" through the diff and driving the other cv out of the side gear.  Sort of like a politician, make a loud sound about something that is inconsequential to get the crowds attention on it, while doing something insidious.   I think this was the original drivers side 1/2 shaft.  I guess it earned its keep, living about 200k.
Now to get the steering straight....
And maybe a new mouse motor.
Post by: bentparts on October 10, 2011, 03:26:42 PM
This is how we learn, and yeah it might have been a red herring to begin with, but just think how much you know about the front drive train now.  ;D Thanks for posting up.
