ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: rodmax on February 02, 2011, 04:23:47 AM
I need to find the name and or number of the pipe that goes into the back of the water pump that the coolant hoses connect to. I have a leak and need a replacement. Thanks.
Suzuki Sidekick 1997,1.6l.
Pipe. water inlet - 17550-58B00
There is an oring on that, where it goes into the backside of the water pump area. So unless you know for sure it is the pipe leaking, I'd check the oring first.
