ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: erik the red on February 02, 2011, 07:17:33 PM
Title: Samurai heat stove hose
Post by: erik the red on February 02, 2011, 07:17:33 PM
What can I use as a replacement heat stove hose? O'Reilly Auto Parts and Autozone don't carry it and I'm not paying 45 bucks for a used one... :ohttp://www.samuraisalvage.com/itemdetail.asp?txtitemname=hose&Submit2=Go!&catid=&itemID=1080 (http://www.samuraisalvage.com/itemdetail.asp?txtitemname=hose&Submit2=Go!&catid=&itemID=1080)
Seems like any high heat resistant, flexible hose should work. Any thoughts?
Title: Re: Samurai heat stove hose
Post by: wildgoody on February 02, 2011, 07:39:18 PM
I got some reinforced silicone hose for my truck, mostly because
of the heat under the hood, silicone doesn't burn at 500* like
rubber hose will, and it doesn't stick to the fittings like rubber
either
Post by: tuxblacray on February 06, 2011, 07:13:02 AM
Other than the 1st few inches from the exhaust manifold heat shield radiator hose should work. A person could even use ABS / PVC / CPVC pipe if they wanted to use something more rigid. Current temps under the hood don't melt the exisiting hoses / wiring as long as a sensible distance is placed between them.
A good rule of thunb would be if you can't lay your hand on the surface then you shouldn't utilize a combustible material in against that area.
You might try a few local wrecking yards for the this diameter exhaust tube. They were used on other vehicles as well, and you may even get lucky. I stopped at a "out in the sticks" salvage yard last week and asked if they had any Suzuki SUV's. The fellow told me there was a sidekick out there if I wanted to take a look at it. I walked back and found it was a Tin Top - the 1.3 was gone. I bought a few parts from it including the hose you are refering to. (I gave a $1 for the hose)
Sometimes the sun shines on a dawgs hind-end......  :laugh:
Post by: wildgoody on February 07, 2011, 11:27:19 PM
Did you grab the diff gears in that 1.3 tin top???
Post by: tuxblacray on February 09, 2011, 03:54:11 PM
Wild... to be honest it was 13 degrees and the wind was howling.The bottom 16" of the Tin Top was buried in the snow. I really didn't give it much of a once over. My real mission was to pick up some Toyota Camry parts. I will be heading back in the future to give it a 2nd look over.
Post by: wildgoody on February 09, 2011, 06:58:38 PM
Ya, well under those conditions, I think they can wait  :o
